Stuck Window
Old Sep 28, 2002 | 09:18 AM
hondaproblem's Avatar
Default I have a problem can u help
i just got home from driving my honda accord 1997
and i cant get the window up what should i do
i need help fast the dealers and autoshops are
Old Sep 28, 2002 | 09:23 AM
gringo7718's Avatar
Default Re: I have a problem can u help (hondaproblem)
its either the motor or the regulator
Old Sep 28, 2002 | 09:30 AM
MyBigNut's Avatar
i bet your contacts are burned up.
take apart the door, get to the controls and clean the contacts, it should work then
Old Sep 28, 2002 | 09:47 AM
Default Re: I have a problem can u help (MyBigNut1)
the other windows in the car go slow to
Old Sep 28, 2002 | 09:49 AM
iam7head's Avatar
yeah, all power window dies sometime or the other, just take the panel off and see what's wrong, if you didnt catch the where's the problem is post up a pic and let the honda techie work the magic.
Old Sep 28, 2002 | 09:54 AM
Default Re: I have a problem can u help (iam7head)
so i should take of the door panel look around and kind of clean it off and if the window stilll doent go up the window motor is dead?
Old Sep 28, 2002 | 10:34 AM
Old Sep 28, 2002 | 11:53 AM
Chiovnidca's Avatar
Don't forget to check your fuses.
Old Sep 28, 2002 | 11:54 AM
carolinaACCORD's Avatar
espacially accord windows.
Old Sep 28, 2002 | 11:55 AM
Default Re: I have a problem can u help (Chiovnidca)
anything else
Old Sep 28, 2002 | 12:00 PM
do you hear the motor trying work??
Old Sep 28, 2002 | 02:54 PM
iam7head's Avatar
Default Re: I have a problem can u help (carolinaACCORD)
after you check the fuse try to hit the switch..if there sound of clicking but the window still stuck=cable snapped(happened few time on me, accord power windows)
You cant really tell what perhap after you open and see it.
maybe it just need some lude(em..about 1.25%)
So do you know how to take off the panel without breaking any tabs?
Old Sep 29, 2002 | 05:11 AM
Chiovnidca's Avatar
Default Re: I have a problem can u help (honda_tech408)
hey, all you mother ***** is wrong!!!!!
Old Sep 29, 2002 | 08:07 AM
b18bEG's Avatar
nothing is broken in your car man. on 1997 accord, the stuck window is normal, i see it alot of times, also fix alot of them. anyway wat u do is go to kragen or sum store and buy a "silicone lublicate spray bottle" and u go home and spray it around the edge of the window and try to move it up and down wit your hands and widow should work like new
hmmm. i guess you are not good at takign advice, you konw sometimes people can be wrong.
Old Sep 29, 2002 | 09:18 AM
Broman78's Avatar
Honda_tech408 your english is wrong but who cares
[Modified by Broman78, 6:18 PM 9/29/2002]
Old Sep 29, 2002 | 02:57 PM
RotaryBzzz's Avatar
Default Re: I have a problem can u help (Broman78)
neat trick:
I'm assuming your window is like mine...works going down, sometimes gets stuck going up. Free fix: wind the window all the way down, then pour water (i keep an old arrowhead water bottle in my back "trunk box o' nicknacks" just for this) down into the sill all the way across. Let it soak for a couple seconds - i use about 1/4 of the bottle. Wind the window up and where it gets stuck...help it with your other hand 'jump' the sticky spot by pulling it up(since obviosly your other hand is on the power window switch). Not high-tech but effective.
Old Sep 29, 2002 | 11:34 PM
iam7head's Avatar
Default Re: I have a problem can u help (Ti1301)
and then you need to get a new speaker and you be greet by smell of fungous smell every morning.JK
I think there a little tap to release the water at the bottem of the door panel, according to popular mechanic.
really dont know about pouring water tho'
Jamesvdh
Jul 5, 2023 11:08 AM
taimysho0
16
Nov 11, 2008 05:25 PM
fongyz22
Honda Civic (2001 - 2005)
Oct 31, 2007 12:54 PM
holeeray
Mar 6, 2005 01:36 PM
H22aInside
Sep 19, 2002 11:12 AM
