Pics of completed vtec OBD1 P72 ECU wiring
If anybody could find(i could not) a pic of a OBD1 P72 ECU wired for vtec.
I would like a reference picture to help me out. i know where to wire it and what to wire but not really sure how it should look. also pictures of the sensors the wires run to would be great.
^Hondapartshero
I went to check out your website and found a Honda Acura OBD1 VTEC conversion swap harness.
Is this all the wires and everything i need to wire vtec from my ECU to my motor/sensors?
one other thing hondapartshero. if im gonna have an aftermarket intake manifold, do i just not hook up the IAB? or do i need to chip/tune my ECU?
IAB COLOR(A17)* isn't that the charcoal/vapor canister?
if you are using an aftermarket intake manifold you won't need the IAB wiring and you can just use the OBD1 VTEC subharness I sell, plus its cheaper. It includes all the wiring and connectors needed to basically plug and play. No need to chip the ECU as it won't throw a check engine light for the missing IAB's.
The body ground goes to a ground on the body or engine, although you could tap into an ECU ground it's easier to just use a good know body ground location
