95 del sol w/ distributor problems
Old Apr 11, 2011 | 03:12 AM
Noodle$'s Avatar
Default 95 del sol w/ distributor problems
i have 95 sol w/ D16Y8 drove it 4 months a young boy down the road loves hondas so i let him hang around & watch me do stuff i did a tune up & went 2 start the car,she fired right up but 4 some reason the kid said it looked like the plug wire wasnt all the way on so he pulls the number 1 plug while motor is running it quit so i buy a new dizzy & it only has 1 plug but the sol has 2 plugs is there an adapter 4 this situation? please any body knows hit me back
Old Apr 11, 2011 | 03:51 AM
Sonia's Driver's Avatar
Default Re: 95 del sol w/ distribator problems
The distributor that you bought is probably for a different engine.
Old Apr 11, 2011 | 04:25 AM
94EG8's Avatar
Seagull Management
Buy a distributor for a D15B7/D15B8 (or just change the coil in yours, most likely everything else is fine)
Old Apr 11, 2011 | 04:42 AM
Jockone's Avatar
What car or engine did you buy the dizzy for?
Old Apr 19, 2011 | 12:42 AM
Noodle$'s Avatar
Default Re: 95 del sol w/ distributor problems
96-99 D16Y8 but the 95 sol didnt come w/ y8 motor it was n the car when i bought it i was selling car to the boy he toke it home i told him not 2 mess with it so what does he do he tryed a dx obd0 dizzy then another 1 that didnt line up so i bought the car back made at the boy 4 not listening cause ive fix that kind of problem b4 so i bought a brand new dizzy not thinking Y8's r odb2 but it dont matter it just dont have 2 connecters just 1 the car has 2 dizzy 1 same number of wires ur basic bl&yellow -blue then 7 other wires the black&yellow r power -blue is rpm & the rest go 2 verious sensers n the dizzy
Old Apr 19, 2011 | 06:40 AM
The seven other wires are for the three sensors (two wires each) and one for the ICM.
You should open the previously working distributor and do some diagnostics rather than simply replacing it. It's probably just a cooked ICM or coil. IMO, the only time you should replace the distributor is if it's physically damaged, or one of the three sensors is bad. You can use a multimeter to test the sensors without taking anything apart. You have to take the cap, rotor, and dust cover off to test the coil and ICM. The coil is easiest to test, but it's probably the ICM that's bad.
Good Luck
Old Apr 19, 2011 | 08:41 AM
NACvicSi's Avatar
I'm confused how did he ruin the dizzy just by unplugging the wire?
Old Apr 19, 2011 | 10:17 AM
hoangy's Avatar
I'm also confused, but for his run-on sentence.
95-delsol-broke
Dec 9, 2010 04:57 AM
(760)doogie
May 28, 2008 09:23 AM
mountaindewguy
Mar 21, 2005 07:26 PM
xoutlawz00x
Feb 2, 2005 06:48 PM
