b16a2 swap in 95 civic dx - throttle issue
I have a 1995 Honda Civic DX and i just did a B16A2 swap form a 99 SI. Car starts but idles funny and i get 2 CEL codes 10 and 19. When i hit the throttle the car starts to die. Any idea what is going on here?
The 10 is from your IAT sensor in your intake. You probably had it disconnected when you hooked the battery back up. Pull and reconnect the battery cable to clear that one.
19 is for the auto tranny lockup control valve. If you pulled this swap out of an EM1, this shouldn't even be an option since they all had manual transmissions. Might want to double check that one.
Are you using the EM1's ECU?
beastmodeej2
Mar 1, 2013 05:23 AM
vr4girl
20
Dec 13, 2009 02:36 PM
skaterdx
Aug 26, 2004 11:11 PM
kurinto
Jan 14, 2004 08:18 AM
