oil in spark plug...what's wrong
Old Apr 9, 2011 | 05:32 PM
1998_4dr_gsr's Avatar
Default oil in spark plug...what's wrong
So i changed my spark plugs today and I noticed 3 out of 4 spark plugs, there is oil on it in. The oil is not from the tip but it's in the area of where the socket grooves are. Is it the plug grommets or head gasket? I just had the valve cover gasket replaced like 10k miles ago.hmphh? any advice appreciated!
Thanks
Old Apr 9, 2011 | 05:42 PM
bank2me's Avatar
Default Re: oil in spark plug...what's wrong
Thanks
Are you saying when you pull off your plug wires and look down into the spark plug holes the spark plugs have oil on them when they are threaded into the block?
Old Apr 9, 2011 | 07:10 PM
Aqualite_Solid's Avatar
Simple tube seals went bad
Old Apr 9, 2011 | 07:31 PM
teg_racer's Avatar
tube seals, remove the valve cover and replace or seal them
Old Apr 10, 2011 | 12:53 AM
goest671's Avatar
yup the seals are bad...same problem i had not too long ago.
Old Apr 10, 2011 | 06:11 AM
hotrodkid85's Avatar
yep same thing happend to me and the after markit ones suck go with honda
Old Apr 10, 2011 | 10:05 AM
bank2me's Avatar
Yea that's what I'm thinking. I wasnt sure where exactly you meant at first but yea the spark plug tube seals need to be replaced.
Old Apr 12, 2011 | 08:57 PM
Si Hatch97's Avatar
had the same problem in every honda ive owned for a couple years.its the spark plugs grommets under the valve cover.once you pull off the valve its good to get the whole set the valevcover gasket and and grommmets with new bolt gaskets.
Old Apr 13, 2011 | 09:02 AM
chriszal1's Avatar
Mm same problem here only my tips have like 3 dots of oil....got a new headgasket kit that brings also the valve covergasket..will indeed due this
koulninja
12
Aug 1, 2011 08:51 PM
skaternak
Oct 2, 2008 10:32 PM
aWeimaraner
Jan 25, 2008 10:52 AM
BB6racer
Jan 18, 2006 05:20 PM
G2_Integ
Aug 26, 2001 03:35 PM
