how to tighten gsr throttle cable?
Old Apr 9, 2011 | 12:27 AM
PowerLeg's Avatar
Default how to tighten gsr throttle cable?
i moved the throttle cable | | and i believei tightened it but im not sure and i felt no difference
its still unsensitive and doesn't really "blip" when i want to blip the throttle to rev match
help please and pictures appreciated
thanks
Old Apr 9, 2011 | 09:27 PM
PowerLeg's Avatar
Default Re: how to tighten gsr throttle cable?
bump
Old Apr 9, 2011 | 10:20 PM
mark@silbernage's Avatar
Sorry, no pics, but you essentially adjust the tension so that the bare cable between the adjuster and the throttle body deflects (bends) between 10-12mm, about 0.4 to 0.5 inches.
If it's still not snappy, you may need to replace the cable. Before you do that, try some WD-40?
I offer this having no with it experience myself - though I will soon - so hopefully someone who's done the deed can chime in.
Good luck
Old Apr 10, 2011 | 06:14 AM
hotrodkid85's Avatar
sounds good to me
Old Apr 10, 2011 | 10:37 AM
PowerLeg's Avatar
the gsr cable looks weird compared to the other ones.
no matter which way im turning it feels exactly the same. not less sensitive not more sensitve
instead of 2 bolts i have ONE bolt and a COG looking thing the **** is a COG doing here instead of a washer/locking nut
gets in the way a lot and i dont think its feeding thru the |_| chamber straight
sorry if its hard to understand
Old Apr 10, 2011 | 10:52 AM
Yea, it comes from the throttle body / passenger side, and from above downward, rather than from the driver / intake side. I don't have a throttle body with the mounting hardware for the cable stay.. so I don't know what to tell you.
There should be nuts on both side of the bracket, any chance you have one on the wrong side so the cable isn't being held tightly? In your case (GSR) the lock nut should be above the bracket, and the adjusting nut (big knurled thing) is below it..
Loosen the lock nut, turn the adjusting nut to pull the cable jacket away (tighten), then tighten the locknut.
You suppose the spring on the throttle body is messed up so it can't put enough tension on the cable?
How about down at the pedal - do the springs there appear to be working correctly?
Between them they account for a lot of that tension you're looking for...
Old Apr 11, 2011 | 12:54 AM
PowerLeg's Avatar
i'll get to readjusting tomorrow
but do you mean pull the cable towards the left tightens it? as in the boot thing gets stretched = it is getting tighter?
IgnitionZ055
Apr 7, 2008 02:22 PM
HondAcura
Jul 19, 2005 05:20 PM
zm_dawg
Jul 12, 2004 09:53 AM
