Air conditioning compressor belt squeals when tight? A/C problem
Old Apr 8, 2011 | 07:29 AM
eastbay92cx's Avatar
Default Air conditioning compressor belt squeals when tight? A/C problem
1988 Civic DX D15B2 engine. The car's A/C compressor was frozen (would not turn at all), so I evacuated the refrigerant and replaced the compressor with a used unit. After refilling the refrigerant and oil using a low side pressure gauge, the air conditioning was functional for 1-2 days. The belt then started squealing once the compressor was turned on for 1-2 minutes. The belt was adjusted properly. The problem seems to be that the compressor becomes too difficult to turn after operating for a short time. Has anyone experienced this? What might be the problem?
Old Apr 8, 2011 | 09:03 AM
Tyson's Avatar
Default Re: Air conditioning compressor belt squeals when tight? A/C problem
i found that it took a new belt to eliminate the squeeling on the AC belt.
i thought it was the tensioner pulley bearing, but a new bearing made no difference even tho it was bad.
Old Apr 8, 2011 | 09:40 AM
This is with a new belt.
Old Apr 8, 2011 | 10:07 AM
Tyson's Avatar
actually, I think its an easy mistake to improperly install the pulley. The washer must go under the thin cover. then you put the nut on. It acts as a spacer, without it or put in the wrong place, the pulley will lock up and fall off.
Consult the shop manual for the right installation.
Old Apr 8, 2011 | 02:33 PM
You are referring to the pulley of the A/C compressor and not the tensioner pulley, correct?
Old Apr 8, 2011 | 04:28 PM
Tyson's Avatar
No, I'm talking of the tensioner pulley.
eastbay92cx
Apr 8, 2011 06:33 PM
FSUseminoleEM1
May 22, 2009 09:27 AM
efyou
Aug 12, 2007 07:40 PM
DBAl
Jul 20, 2006 09:17 AM
dip-set
Jan 13, 2004 01:23 PM
