power locks
BUMP^ I am having a similiar problem with my passenger side. It unlocks with key or by hand, although with some difficulty and it always tries to relock itself if the handle isn't opened in time. It just gets stuck in a vicious cycle if I try to use the power locks, it clicks as if trying to unlock and then doesn't move the latch so the system automatically relocks it a few times.
not to jack ur thread but im having a similar issue. when opening the car door from the outside with the key, only the driver's door opens. also the door lock switch inside on the driver's door does not work so i figured it was the actuator.
can somebody post pics of the actuator and its location inside the door? I pulled down the doors of my 2000 Civic Si Coupe but i'm not sure what it looks like or if the actuators are even in my doors
would be a big help. thanks!
That is correct. One most models, you need to have the stock radio in order for the keyless remote to work.
humble007
Sep 12, 2005 12:10 PM
humble007
Audio / Security / Video
