g22 help
Old Apr 8, 2011 | 03:25 AM
turboaccord77's Avatar
Default g22 help
hey guys,i need a little help.what head gasket is used for g22 build?have h22 head and f22b2 block.ive heard everything from h22,h23 and f23.anybody now for sure?also any info on oil ports to be pluged or unpluged.i am not a mechanic but my boy is.just resurching some info.we wired vtec but vtec does not seem to work.93 accord with p28 chipped ecu.thanks for any info.
Old Apr 8, 2011 | 04:40 PM
slomofo's Avatar
GDD Member
Default Re: g22 help
Use the gasket that matches the block.
Old Apr 8, 2011 | 07:11 PM
SLOWLYcruisin's Avatar
i heard it was a f23 headgasket
Old Apr 15, 2011 | 11:59 AM
Cortez65's Avatar
im also doin the 'g22' build and ive heard most frequently that the f23 gasket was used. and as far as the oil ports being plugged its the last two ports on the timing side that need to be plugged. you can either weld them shut with a bolt or hondabond em. my head was once used for this build so it was already preped.
mijos
Sep 5, 2020 05:56 PM
912.2Accord
Jan 7, 2012 07:01 AM
titan101
Sep 23, 2011 03:48 PM
eg6madness
Oct 5, 2007 02:50 AM
killacam661
Sep 11, 2007 01:57 PM
