Transmission & Drivetrain Gearboxes, Differentials, Clutches
5th gear grinds sometimes
Old Apr 7, 2011 | 09:12 PM
nitewolf's Avatar
Default 5th gear grinds sometimes
I had some questions I searched found a few problems but not like mine.
I have a s4c b16 si tranny
When I punch/smash from 1st to 2nd and then go straight to fith it grinds and don't go in, If I let the rpms go down it goes into gear and dont grind. My reverse is hard to get into most of the time. When I shift normal from 1-5 it's butter. Is this a early sign of my tranny going out.
-new Honda mtf was put in 300 miles ago
-clutch fluid has been flushed and re-bleed with prestone synthetic brake fluid
-pw:Jdm magnetic drain plug
Old Apr 8, 2011 | 09:03 AM
David @ Synchrotech's Avatar
Default Re: 5th gear grinds sometimes
Sounds like a worn 5th synchro and sleeve.
Old Apr 10, 2011 | 08:23 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
^^ i replaced both on mine and it still grinds
Old Apr 10, 2011 | 08:36 AM
unusual71's Avatar
sounds like a worn syncro for sure. Gotta be careful that everything goes back together right or you'll still have problems.
ohsnap did you follow the manual to a T? stuff like the sleeve and hub look almost identical in both directions but there is only 1 right way.
Honda MTF is great stuff if you have a top notch trans, but once it gets warm its thin like water, so for something a little less healthy i like to run a thick oil like Motul 75w90 trans oil.
azntuner
Feb 2, 2008 08:27 PM
Ricta
Jul 1, 2005 01:11 PM
totalfxaccord
Mar 21, 2004 12:18 PM
elevatethis
41
Nov 24, 2003 12:02 AM
RTW DC2R
Sep 14, 2003 06:02 AM
