vtec switch
Old Sep 27, 2002 | 10:02 PM
4dohs4mohoes's Avatar
Default vtec switch
ok guys...heres the deal...i put a d15b (SOCH VTEC) into my 91 hb. i have a shift light that i want to use to engage my vtec. im not planning n changing the vtec points so dont worry about that. but i was just wondering if i do this will need to get a new ecu or will my dx ecu work? and will my dx disributor work too. thanks guys
Old Sep 28, 2002 | 05:03 AM
civicwagonman's Avatar
Default Re: vtec switch (lilgreenhonda)
not sure on that. isn't that the head that has a two stage vtec? what idid it come out of a vx or cx? normally the shiftlite would work fine, jsut not sure what it will activate if its the two stage. anyone else know?
Old Sep 28, 2002 | 06:09 AM
Mugen Dom's Avatar
Default Re: vtec switch (civicwagonman)
uhhh no u cannot use ur dx distirbuter or the ecu u need to run mpfi and use at least a p28 from a 92+ si with the d16z6
Old Sep 28, 2002 | 07:08 AM
ngkplugs's Avatar
Default Re: vtec switch (JdMB16Ahatch)
deff cannot use ur dx ecu or dizzy for shizzy come on now nizzy use ur hizzy
Old Sep 28, 2002 | 07:50 AM
.nate's Avatar
you can do it without changing ECU's. Get a Chilton's manual, and look at the wiring for the d15b. im running a similar setup. Youll also have to modify the distributer somewhat.
Old Sep 28, 2002 | 08:10 AM
Mugen Dom's Avatar
Default Re: vtec switch (N8-T)
ull have issues with fuel having a bigger cam and not enough fuel....the d15b is similar to a z6 which has a diff distributer design from the b15b2 which is in a crx it wont bolt on so i recomend getting a z6 distributer and ecu running obd1 and have the best setup u can have
nicolas1320
Nov 6, 2011 04:18 PM
SpdFrk
Nov 28, 2003 02:06 PM
fastgreenmachine
Mar 13, 2003 07:13 PM
JD_B18CDX
Oct 21, 2002 08:22 AM
woodbine
Jun 6, 2001 11:53 AM
