How to replace valve seals?
Old Apr 7, 2011 | 12:38 AM
///Mathew's Avatar
Default How to replace valve seals?
I've got a b18a1 for my civic that I partially disassembled and now am reassembling, so I bought a top end gasket kit, including head gasket, exhaust, intake etc.
The kit also came with valve seals and I was wondering how easy it is to install them. I don't have any specialty tools nor the experience to remove the valves/springs etc. I was wondering if the valve seals can be replaced without getting in too deep.
Thanks guys.
Old Apr 7, 2011 | 03:50 AM
CWBETB's Avatar
Default Re: How to replace valve seals?
Looking for some answers on this also. Nice build btw
Old Apr 7, 2011 | 03:57 AM
Old goat's Avatar
https://honda-tech.com/forums/showth...e+seal+removal
Old Apr 7, 2011 | 07:48 AM
4drEF's Avatar
Keyboard Humorist
As an alternative for those that don't have shop air or a leakdown tester, you can rotate the crank so that the piston is all the way down and fill the cylinder with nylon rope. When it's full, then turn the crank slowly to compress the rope and keep the valves up. It works, harms nothing, and is a recommended method if you don't have shop air.
Old Apr 7, 2011 | 07:58 AM
turtleman321's Avatar
^^^ that's correct. Use it all the time.
One problem he doesn't have specialty tools to remove the valve springs and retainers
Old Apr 7, 2011 | 09:59 AM
CRX Toad's Avatar
And use one of these it makes things so simple. http://www.tooltopia.com/lisle-36050.aspx you will thank yourself. That with either air or nylon rope will make it a snap.
Old Apr 7, 2011 | 10:38 AM
4drEF's Avatar
Keyboard Humorist
Also, you need a set of bent feeler gauges rather than straight ones to set the valve lash.
Good time to put in a new cam as well
jdm_sai
May 8, 2020 09:29 PM
live4soccer7
17
Jul 1, 2019 06:44 AM
GaryTuesday
Oct 26, 2013 09:57 AM
bllabong89
Mar 30, 2009 12:59 PM
MisterB
Jun 4, 2003 09:31 PM
