Help on D16 build
Old Apr 5, 2011 | 07:25 PM
vtecfreak15's Avatar
Icon2 Help on D16 build
I have a d16y8 head im building. Ive got aem fuel rail, fpr and rc 440cc injectors, blox stage 3 cam with blox valves, springs, and retainers. The head's been port and polished with 5 angle valve job. My Questions are, will this be ok with stock bottom end. Will there be any clearance issues. What should i set my fuel pressure at?
Any info or ideas are helpful.
Old Apr 5, 2011 | 08:32 PM
vartok's Avatar
Default Re: Help on D16 build
with all that head would, i would imagine you would need to get it tuned (expecially with the new injectors)... so i would think touse are questions for the tune shop
Old Apr 5, 2011 | 08:50 PM
I have all the stuff for tuning including a chassis dyno, im just trying to find someone thats done something similar to work out a few kinks.
Old Apr 5, 2011 | 09:25 PM
Any ideas... you dont have to answer the questions exact i just want some ideas, like if anyone has used this head or the blox cams or anything like that.
Old Apr 5, 2011 | 09:32 PM
ok ive had a ht acount for a while, but never really used it... am i posting in the wrong place or something?
Old Apr 5, 2011 | 09:33 PM
Swifty92's Avatar
all that work and money put into a great project so far. mine as well do it right. I suggest rebuilding The Bottom end. I Did It and Im always on a super low budget. If your worry is clearance issues then clay the motor.
http://www.c-speedracing.com/howto/claymotor/clay.php
Old Apr 5, 2011 | 09:48 PM
i plan on rebuilding the bottom end but itll be around 2 months before i can and i need the car done within a week. Im just looking for ideas and/ or tips esecially for tuning if antones got any ideas on a starting basemap.
Old Apr 5, 2011 | 10:30 PM
anyones*^
Old Apr 6, 2011 | 03:14 AM
grumblemarc's Avatar
The Grumpiest
Neptune.
Old Apr 6, 2011 | 03:19 AM
hondamark35's Avatar
i know it wasn't what you were asking about... but aren't those injectors a little- way over sized?
Old Apr 6, 2011 | 03:21 AM
The Grumpiest
I would say yes. But if gets it tuned it won't be an issue. If he does NOT....
Old Apr 6, 2011 | 03:24 AM
true. and maybe he's planning on a turbo in the future...
Old Apr 6, 2011 | 03:28 AM
The Grumpiest
Doesn't sound like it. Sounds like an N/A build. I find it hard to believe that all this work is getting done with little to NO thought on engine management. Recipe for catastrophic fail right there. If it were me I'd have built from the bottom up. The top end is good for nearly 300hp stock.
Old Apr 6, 2011 | 09:28 PM
i have given thought for engine management i just ask for tips... i didnt ask for someone to be a smarta**!
Old Apr 7, 2011 | 12:51 AM
Garcia505's Avatar
Question if u have 275 cc injectors in a mini me swap would it need to be tuned sorry off topic
Old Apr 7, 2011 | 02:51 AM
The Grumpiest
Highly doubtful. Or you would've said something to the effect of "I'm thinking about running CROME or Hondata." instead of "got any tips?".
Sorry. Smartass is my profession. You should check the All Motor forum or the Engine Management and Tuning forum. That's my tip.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/
https://honda-tech.com/forums/engine-management-tuning-124/
Old Apr 7, 2011 | 08:55 AM
Aparently you dont read
Old Apr 7, 2011 | 10:20 AM
The Grumpiest
But if you have all that tuning equipment why would you then need tips on tuning? Especially since you said you have "all the stuff". If you need to ask with all this in mind then perhaps you need to seek out someone that actually does this for a living. I don't recall the last time I ever saw someone that dyno tunes vehicles ever come onto a forum and ask for tips.
Old Apr 9, 2011 | 09:34 PM
i said i have one, as in access to one. we have one at my college, but my teacher doesnt have anything for obd1 so i need tips on what to get. He'll be doing it. I have crome and a chip burner but i want a little something more than crome pro.
Old Apr 9, 2011 | 10:18 PM
owneyboy's Avatar
lose the blox cam.. loss of massive torque , bad power band. a copy of a copy is crap lol you will only see a 10hp max fully tuned around 6-7,000 rpms
Old Apr 10, 2011 | 12:11 AM
Solster's Avatar
well if your going to try and tune it at school then you need to buy a RTP for the ecu and get a lc-1 wide band with mufler clamp mount.
try looking at Xeonocron for them
also with that big of injectors get a walbro fuel pump and run E85 it's cheap and is rated around 110 octane
Old Apr 10, 2011 | 03:39 AM
The Grumpiest
Neptune RTP. And after all that headwork you'll still be slow. I gar-ron-tee. I don't know why people think that if they modify the head like they do on V8s that somehow TREMENDOUS power is going to be unleashed. Doesn't matter if you swap it as in a mini-me or build it. Not happening. Those heads are pretty efficient from the factory.
prsferna0918
Jan 15, 2011 10:08 AM
MyHotsh
May 8, 2006 12:02 PM
precord96
Sep 26, 2004 01:01 PM
94B18B1Teg
Jan 25, 2004 09:16 AM
Stroker
Nov 20, 2002 12:17 PM
