head work help
Old Jan 13, 2011 | 12:29 PM
prsferna0918's Avatar
Default head work help
Well i'm currently looking to rebuild my head with titanium retainers, springs and possibly new valves. I also might do a port and polish so my question is what company/companies make some high quality parts that are affordable basically looking for the biggest bang for my buck. I do know that skunk 2 and blox make retainers, springs and valves but i have never actually met anyone that used them so does anyone know if they are any good? Is there better companies out there. I will be doing all of the work my self so i must need to get the parts any help will be appreciated.
Old Jan 13, 2011 | 01:58 PM
NAH2B's Avatar
Default Re: head work help
there are alot of good options out there for valvetrain etc.
which engine and setup? n/a or f/i?
Old Jan 13, 2011 | 03:31 PM
N/a for now but hopefully boost some day in the future my goal for now is atleast 200hp its a jdm gsr block and head skunk 2 maniflod 4 to 1 header 2.5 exhaust cold air intake. I also have some ctr cams aem cam gears walbro 255 fuel pump skunk 2 fuel rail h22 injectors and blox adjustable fuel pressure regulator that I plan on installing after I rebuild the head I'm just not tryin to break the bank in doin so.
Old Jan 13, 2011 | 07:14 PM
NAH2B's Avatar
if your gonna be running ctr cams just go w/ supertech valvetrain it will do the job and its cheap.
Old Jan 13, 2011 | 08:27 PM
now will those hold up well if i do f/i in the future?
Old Jan 13, 2011 | 08:30 PM
dragallmotor24's Avatar
Supertech Valvetrain
Old Jan 13, 2011 | 09:02 PM
where can i order supertech from?
Old Jan 14, 2011 | 07:28 AM
4piston's Avatar
The Skunk pro spring is a lot nicer than that ST stuff, Ferrea is good quality, and I think the Brian Crower B series springs are made by PAC. Springs are pretty important so make sure you get something that will last and are setup for your application.
Old Jan 15, 2011 | 09:54 AM
How good are the toda springs and titanium retainers are they high quality stuff or just overpriced
Old Jan 15, 2011 | 10:08 AM
B18c1turboedEK's Avatar
I suggest Ferrea set up. I had bad luck with Supertech crap. It cost me alot of money too fix, make sure you get the right springs with the presure you need also.
vtecfreak15
22
Apr 10, 2011 03:39 AM
WONG FRIED RICE
Aug 24, 2006 01:34 PM
ANG_E3
May 2, 2006 06:16 PM
robGSR
Nov 2, 2004 05:14 PM
94B18B1Teg
Jan 25, 2004 09:16 AM
