B20 vtec leaking oil from dizzy
Old Apr 5, 2011 | 10:22 AM
hondalove414's Avatar
Default B20 vtec leaking oil from dizzy
soo my eg coupe has a b20 vtec in it and its leaking oil from the cap on the dizzy right onto the upper raditor house down the the tranny. I replaced the o-ring but its still leaking. any advice from someone would be cool.
Old Apr 5, 2011 | 11:20 AM
JDMxTai's Avatar
Default Re: B20 vtec leaking oil from dizzy
most likely didn't install it right or someone handed you a bad o-ring.
Old Apr 5, 2011 | 12:27 PM
mik101's Avatar
Were the cams from a running motor? I worry something bad could be going on there or torque wasn't applied evenly and in correct order for the cam caps. Another possibility is a bad bearing in the distributor.
Someone else want to chime in here?
Old Apr 5, 2011 | 12:50 PM
I put it on right lol its not that hard and it was brand new from Honda. I am thinking a bad internal seal inside the cap
Old Apr 5, 2011 | 01:55 PM
nub's Avatar
nub
^^ This. Take the cap off and if there is oil inside the housing the shaft seal needs to be replaced.
Old Jun 29, 2011 | 12:35 PM
orangesmurf's Avatar
thanks
B0Z0
Jan 19, 2011 07:53 PM
itr1244
35
Jul 12, 2010 11:29 PM
zeiram13x
Jul 11, 2008 02:33 PM
wm5holla
Jan 5, 2003 04:10 PM
