Besides simply bolting on my turbo kit, what else should i do?
Old Sep 27, 2002 | 07:02 PM
foreverjenn's Avatar
Default Besides simply bolting on my turbo kit, what else should i do?
Planning to install my drag gen. 3 turbo kit on my ITR, but what else should I do besides simply bolting on the kit. Should I run colder spark plugs? Retard the timing? etc...
Old Sep 27, 2002 | 07:31 PM
rjardy's Avatar
Default Re: Besides simply bolting on my turbo kit, what else should i do? (foreverjenn)
Timing rolled back would be good as well as running colder plugs..
Rob
Old Sep 27, 2002 | 08:58 PM
pelotudo's Avatar
NGK BKR7E-11's, Timing -5degrees, What kind of Fuel management?
jB
Old Sep 27, 2002 | 09:19 PM
Smashback's Avatar
Ride her hard and put her away wet.
Old Sep 27, 2002 | 09:53 PM
tony1's Avatar
Default Re: Besides simply bolting on my turbo kit, what else should i do? (PeloTudo AKA Gringo)
5 degrees is too much retard unless you are running more than 9psi. I would set base timing around 14-15 deg.
Old Sep 27, 2002 | 10:03 PM
Etylorcen's Avatar
Default Re: Besides simply bolting on my turbo kit, what else should i do? (tony1)
Old Sep 28, 2002 | 04:01 AM
pelotudo's Avatar
Default Re: Besides simply bolting on my turbo kit, what else should i do? (Etylorcen)
Hrmmm, maybe that's why I have friggin shitty throttle response and low end hesitation...
Old Sep 28, 2002 | 08:56 AM
sutrusu's Avatar
i thought you couldn't change the ignition timing on the obd2 cars? the computer just sets it back to stock, right?
Old Sep 28, 2002 | 09:06 AM
Mase's Avatar
Default Re: Besides simply bolting on my turbo kit, what else should i do? (sutrusu)
You are suppose to jump the service connector.
yeegsr
Oct 13, 2004 03:16 PM
dominate9
Dec 4, 2003 05:05 AM
B_1_8_hatch
Oct 18, 2003 07:29 AM
guest
Jun 23, 2002 06:04 PM
1sick4door
Feb 14, 2002 09:39 PM
