EF2 With B16a "Mystery Axle"
Old Apr 4, 2011 | 02:54 PM
JDM***CD6's Avatar
Default EF2 With B16a "Mystery Axle"
I've got this EF2 With a Xsi B16a Motor and just recently the Driver side axle went out but i went to get a new one and all of the axles they had were shorter, The Axle is about 27" inches Ive tried doing research but just get lost in the links...
What is the correct axle for this car? Ive tried Del Sol,Civic, and Integra Axle and no luck? Come thru for me Honda-tech I'm in need of this Thank you...
Old Apr 4, 2011 | 11:12 PM
CivicSD's Avatar
Default Re: EF2 With B16a "Mystery Axle"
correct axle should be 90-91 integra (non ABS) provided that you are using the correct intermediate shaft.
Old Apr 5, 2011 | 06:08 AM
whynott_ef's Avatar
I agree. DA non ABS.
Old Apr 6, 2011 | 11:43 PM
10psiLsEf2's Avatar
da abs or not just has a tooth wheel.
Old Apr 6, 2011 | 11:58 PM
crx_si-r's Avatar
try a 88-89 integra D16A1 axle. this is what i am running in my 90 crx with DA intermediate shaft and 90-91 EX front knuckles. these are slightly shorter than DA axles so less binding.
Old Apr 7, 2011 | 10:54 PM
91HatchSTD's Avatar
This link might help answer your question. http://crxcommunity.com/viewtopic.ph...=13024&start=0
Old Apr 8, 2011 | 12:19 AM
hatchet_honda's Avatar
axles all depends on halfshaft used...does this axle have a male end on both ends?
vdubsduncutit
13
Jun 2, 2010 05:00 PM
13g-crx
Feb 12, 2007 01:14 AM
T"u"Rtle
Nov 8, 2005 05:02 PM
stealth civic
May 29, 2004 04:22 PM
