1990 crx si d16a6 turn over but won't start.
Old Apr 4, 2011 | 01:51 PM
TimCrxSir's Avatar
Default 1990 crx si d16a6 turn over but won't start.
I got home turn off the car and then start-up the car after opening the garage.
The car start right up with no problem while i was moving into the garage the car stall and die completely.
So i try starting it up but it wouldn't fire up. I ask a friend AKA [kaiba] to help me trouble shoot the engine.
Got spark and fuel-CAN HEAR THE FUEL PUMP COME ON WHEN KEYS HALF WAY TURN OVER but low compression cylinder 1-4= One's-120 Two's-90 Three's-89 Four's-100.
ALSO SPOT ANOTHER FLAW IN THE TIMING SYSTEM. TIMING BELT JUMP ABOUT 1 TOOTH AND CHANGES TIMING BELT AND WATER PUMP AND LINE UP TO MARK STILL NO START.
and yes, I HAVE THOUGHT ABOUT A MINI SWAP NOT INTEREST TO MUCH WORK/TIME WHICH I DON'T HAVE.
I HAVE READ ALOT OF BLOG ABOUT TIMING CAN'T CAUSE A PROBLEM THIS BIG WHEN IT BEEN REPLACE.
ALSO CAN I HAVE BENT VALVES??ANY IDEAS/ADVICES WILL HELP!
WHAT'RE MY OPTION TO REPAIR THIS ENGINE P.S UNDER 800 BUDGET._THANK YOU IN ADVANCE.
Old Apr 4, 2011 | 02:17 PM
1990edsedan's Avatar
Default Re: 1990 crx si d16a6 turn over but won't start.
How many miles/kms on the drivetrain?
Old Apr 4, 2011 | 05:21 PM
TimCrxSir's Avatar
180,000
89civicb16a1
Nov 19, 2010 07:12 PM
89civicb16a1
Nov 19, 2010 12:41 PM
nighttrain33
Mar 23, 2008 01:38 PM
96_9c1
Jul 24, 2006 03:08 PM
Will_H
Apr 18, 2004 03:49 AM
