B20-v with GSR girdle question
So I am going to put a B20-V together and And boost it. I am going to use a GSR girdle for the bottom end, and I know that I need to use the pick-up/windage tray from a GSR to make that work. I just bought a Moroso oil pan for the LS/B20 and want to use it. Makes for a nice clean return line fitment. My question is:
#1. What makes it so that my LS Moroso pan will not fit?(pick up to low?)
#2. With a baffled oil pan, do I need to run the windage tray at all?
You do not need to run a girdle. the sleeves will give out long before the girdle would help out and running a gsr girdle involves some work, better off picking up a KMS girdle for ls. but if you've already done all the work then you need to run a gsr oil pan its deeper than an ls pan
I looked around, and could not find a different part number for them. All that was listed was a Honda B18a/b/c. I'm gonna wait to make a decision till I get the pan.
xxmikexx206
Jan 8, 2007 09:08 AM
