B20-v with GSR girdle question
So I am going to put a B20-V together and And boost it. I am going to use a GSR girdle for the bottom end, and I know that I need to use the pick-up/windage tray from a GSR to make that work. I just bought a Moroso oil pan for the LS/B20 and want to use it. Makes for a nice clean return line fitment. My question is:
#1. What makes it so that my LS Moroso pan will not fit?(pick up to low?)
#2. With a baffled oil pan, do I need to run the windage tray at all?
Re: B20-v with GSR girdle question
You do not need to run a girdle. the sleeves will give out long before the girdle would help out and running a gsr girdle involves some work, better off picking up a KMS girdle for ls. but if you've already done all the work then you need to run a gsr oil pan its deeper than an ls pan
When you install the girdle or any other mains besides the ones that came on the b20, you will need to line hone the mains.
I looked around, and could not find a different part number for them. All that was listed was a Honda B18a/b/c. I'm gonna wait to make a decision till I get the pan.
xxmikexx206
01-08-2007 09:08 AM
