stock asr brace with stock ex swaybar
Old Apr 4, 2011 | 09:19 AM
724chris's Avatar
Default stock asr brace with stock ex swaybar
will that work o na del sol i thought i read somewhere that you have to use a type r swaybar with the asr brace.aand if so why cant you use a ex swaybar?
Old Apr 4, 2011 | 09:21 AM
grumblemarc's Avatar
The Grumpiest
Default Re: stock asr brace with stock ex swaybar
You can use what ever swaybar you want with the ASR brace. I never saw anything that said you cannot use a stock bar.
Old Apr 4, 2011 | 09:26 AM
Vindicator9000's Avatar
318 Curves, 11 miles
No reason you can't use a stock swaybar. However, you will have to get the correct D-brackets and bushings for that bar, and you'll have to get the correct endlinks for your car. The ASR is compatible with just about any bar.
I really don't know whether DelSols come with endlink mount points or not, or which style they are. Regardless:
1. If you don't have endlink mounts on your LCAs, you'll have to get LCAs with mounts.
2. You'll have to get endlinks that match the style of mounts on the LCAs. If you get EG-style LCAs, you'll need EG-style links.
3. Don't use EK/EM links on EG arms. They'll probably bolt up, but the geometry is all wrong.
ej1gsr!
Apr 24, 2010 06:20 PM
roycivic92
Dec 26, 2007 03:39 PM
dFreezy
Sep 23, 2004 11:46 AM
M-EJ1
22
Jul 26, 2002 06:04 AM
