crx d16a6 boosted valve cover breather smokin
I have a 88 crx d16a6 turboed and just started noticing the vavle cover breather nipple smokes and under boost smokes even more and spits just a little oil y?
the explosion blow by the gap between the piston and the cylinder.you can use a catch can to keep the spitting oil off your engine but only a engine rebuilt will fix it if it's to bad...take a compression test you will be fix on your engine health
No, you have to much pressure in your motor from when you hit boost and your motor is not able to breath just from that one nipple. You will have to put a catchcan setup and weld bungs on your valve cover look up catchcan setups to see what I'm talking about. To the kids who said your motor is going to blow, not true, why do freshly built motors have catch can setups with 6 breathers? obviously they are not going to blow, its because of the extreme amount of pressure in the motor that needs relieved.
Gummiej
Jul 18, 2006 12:09 AM
Sprockets
Jan 3, 2006 07:30 AM
underpressure02
Oct 17, 2003 06:29 AM
