question about rust!
Old Jul 7, 2005 | 10:10 PM
veilsides2000's Avatar
Default question about rust!
okay i had missshifted and took my valve cover off today and found one of my valve retainers broken in half. i didnt feel like putting the valve cover back on instead i just put it over it and did not screw it back on. my question is that if i leave it like this will the inside start to rust. like where my cams are???? if yes then what can i do to prevent that. should i cover it up with something??? i don't have a garage, only a damn driveway. any opinions are appreciated
Old Jul 7, 2005 | 10:21 PM
VTteg's Avatar
Default Re: question about rust! (veilsides2000)
i would think everything is oiled enough already, but I would at least PLACE the valve cover back on.
Old Jul 7, 2005 | 10:34 PM
Default Re: question about rust! (VTteg)
yes i did put the valve cover back on but i jsut didnt screw it back into place should it be fine though???
Old Jul 7, 2005 | 10:36 PM
numbnuts22715's Avatar
I think you should be fine as long as its sitting flush.
Old Jul 8, 2005 | 08:50 AM
Default Re: (numbnuts22715)
flush??
Old Jul 8, 2005 | 09:41 AM
Master23's Avatar
Default Re: (veilsides2000)
The insides wont rust if its got motor oil all over it. The motor oil contain additives that prevent rust from happening.
Old Jul 8, 2005 | 11:11 AM
Joreln's Avatar
it wont rust but if you try to run the motor that way it will leak oil
id definitely fasten the valve cover down
sh!ft
Welding / Fabrication
Aug 12, 2010 01:06 PM
Mr. Em1
10
May 2, 2009 03:38 PM
boosted91crx
Mar 31, 2009 11:19 AM
racereaper7
Honda Civic (2006 - 2015)
Apr 12, 2008 06:19 PM
jdmcivicferio
Mar 17, 2003 01:59 PM
