need help with spark and fuel pump problem
Old Apr 2, 2011 | 06:02 PM
bladesz42's Avatar
Default need help with spark and fuel pump problem
recently i bought a 93 vx hatch and it doesnt run, it had no spark and the fuel pump didnt kick on when i got it. i got it home and so far changed plugs, wires, cap, rotor, coil, fuel pump, and main relay and still NOTHING! im not sure were to go from here. H-T please guide me to get my hatch running.
my friend is coming over in a bit and we are going to switch out the fuse panel and see if that does anything.
Old Apr 2, 2011 | 07:20 PM
hannslebo's Avatar
Default Re: need help with spark and fuel pump problem
Give a little more info on the motor, car, mods, auto/manual. What did the previous owner say? I'm sure someone will chime in. Check all your grounds and connections.
Old Apr 2, 2011 | 07:27 PM
bladesz42's Avatar
1993 honda civic vx hatch, d15z1, ebay header and short air intake. previous owner got it from a friend and said it just stopped one day and they couldnt get it started. he said they thought it was a spark issue.
Old Apr 2, 2011 | 08:38 PM
fonkernuckle's Avatar
Please be more specific as in the car cranks or does not crank, the car starts or does not start or the car cranks but does not start.
Old Apr 2, 2011 | 08:49 PM
XYRS2LT's Avatar
Is the timing belt intact? Pull the cap off and crank motor, if rotor turns, belt is there.
Old Apr 2, 2011 | 10:57 PM
hannslebo's Avatar
Any CEL?
Old Apr 3, 2011 | 02:18 AM
CivicNorway's Avatar
check the G101 ground in the engine bay.
Old Apr 3, 2011 | 04:45 AM
bladesz42's Avatar
the car cranks but does not start, yes timing belt is there, there is a CEL when the key is in the on position.
Old Apr 3, 2011 | 04:55 AM
219's Avatar
219
can u hear a clicking sound under the dash? if not chances are its the main relay..
also check all the grounds...theres a ground on the top of the valve cover going to the core support,one on the thermostat housing and one on the transmission if one of them isnt hooked up u will never get spark
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/ heres how to check your cel
Old Apr 3, 2011 | 04:58 AM
219's Avatar
219
aka the thermostat ground
Old Apr 3, 2011 | 05:44 AM
vansxskater's Avatar
https://honda-tech.com/forums/showthread.php?t=1901557 heres how to check your cel
It says he replaced main relay.
Old Apr 3, 2011 | 09:17 AM
bladesz42's Avatar
pic on thermostat ground? the vc ground was on the mount. now is on the correct spot.
Old Apr 3, 2011 | 09:51 AM
hannslebo's Avatar
Ground on thermostat (sorry for the small pic...you can look it up on google though)
Old Apr 3, 2011 | 12:41 PM
bladesz42's Avatar
did that, also found out it was a fuse. thanks honda tech. now its sputting around 3k rpms. im going to clean out the fpr tonight and time it and see if that fixes it
Old Apr 3, 2011 | 12:45 PM
bladesz42's Avatar
its also idling rediculously low
Old Apr 3, 2011 | 04:35 PM
hannslebo's Avatar
Clean iacv and fitv...may help the idle...u can also adjust the idle in the fitv while it's out. RonJ has a good write up on both in his signature.
pmey
May 26, 2009 01:11 PM
plantmylotus
10
Oct 14, 2008 10:49 AM
BluRgio
10
Jan 28, 2007 05:06 PM
SkIp_Civic_Ek6
Jun 25, 2006 04:54 AM
esoterEK..
Feb 10, 2004 09:40 AM
