broken bleeder bolt
was bleeding my brakes on a 94 si on the rear right and snapped the bolt in 2 pieces and cant find a replacement one need help on finding another bolt for it somewhere in the western washington area if one is available for pickup immediatley.
the brakes will still work, if you broke the head off, it will still hold fluid
as for replacing it, people who dont have the tools or exp just buy another caliper,
replacing just the screw would require you to drill a hole into the screw and using an bolt extracting kit to unscrew it. theres a low rate of success doing this though
i tried autozone and orielly's i got the screw out and everything so the car wont run without one cause it will leak but i cant find one even tried going to ace and home depot they dont have em
If you really can't find one anywhere (which I find really hard to believe) buy a wheel cylinder for a civic with rear drums (they don't cost much) and use the bleeder from it.
You can buy just the screw for $5-10 at Advance. They have it listed as a "bleeder screw".
Calipers aren't terribly expensive. I think they were $47 for good ones. And advance auto has online coupons that makes stuff more reasonable.
thanks found a bleeder bolt. now what i need is a banjo bolt the one on mine is rusted anyone know where i can find those so i can replace them i called around parts store like napa and stuff they dont have em its a m10 1.0 threading on it and it has like an L shaped whole in it. they said they dont carry them. know anyone who might? other then dealer?
oranginal
Feb 16, 2012 07:01 PM
