GSR 11:1 comp. built head, turbo questions
Old Apr 2, 2011 | 04:39 PM
chunk0806's Avatar
Icon2 GSR 11:1 comp. built head, turbo questions
I have a Turbo'd B16A2 in my SI right now but i just bought a freshly rebuilt GSR with an LS crank and 11:1 high compression pistons. Im in the middle of building my B16 head- (port, polish, 3 angle valve job, CTR cams, etc.) and am looking to get around 350whp. but what my question now is what should I do to the motor (other than an amazing tune) to try to insure that my motor isnt going to blow?
Old Apr 2, 2011 | 05:03 PM
racebum's Avatar
Default Re: GSR 11:1 comp. built head, turbo questions
the same thing every s2k and itr owner has done with the same compression
1. keep intake air temps down as much as possible
2. keep the engine cool
3. stay conservative with the tune {in fact tuning it on a 90deg day isn't a bad idea}
an optional is running e85 if it's possible
Old Apr 2, 2011 | 05:13 PM
C_Rock77's Avatar
Well, you DO realize that running that B16 head is going to lower the compression from what is is with that GS-R head.
Old Apr 3, 2011 | 01:12 PM
chunk0806's Avatar
I didnt realize that. I always just figured that a GSR head was more open than a virgin B16 head.
what is the weak part of a gsr? do i really have anything to worry about as far as the sleaves dislodging?
Old Apr 3, 2011 | 01:20 PM
2k.civic.si's Avatar
you can use the b16 head on that gsr bottom and a little thicker headgasket from cometic to easily get you down to 10.5:1 compression would be be fine for a 350whp daily driver.
Old Apr 4, 2011 | 05:45 PM
chunk0806's Avatar
right on, exactly what i wanted to hear. you think ill have any trouble running that compression and running 92 octane pump gas?
Old Apr 4, 2011 | 06:27 PM
walk in the park.
djordan1
Jul 19, 2010 05:20 AM
hYbRid_Eg6
Dec 20, 2009 07:01 PM
93da07
Jul 25, 2005 09:10 PM
DRIVENRacing
Apr 16, 2005 04:37 AM
Hybrid CRX
Mar 22, 2004 07:50 AM
