wont rev past 3.5
Old Apr 2, 2011 | 01:36 PM
kbear's Avatar
Default wont rev past 3.5
i just finished building a ls/vtec motor (b18/b16) but for some reason it wont let me rev past 3.5. currently im running a boosted gsr map on my s300. i know there are a few cel that are being thrown right now such as icv, vtec (its not wired up), and some vacuum issues.
could those be the cause of it not reving past 3.5? or is just because it isnt tuned?
Old Apr 2, 2011 | 01:43 PM
Destructive-'s Avatar
Default Re: wont rev past 3.5
check that the tps and the map sensor arent switch around
Old Apr 2, 2011 | 04:47 PM
YellowDB1's Avatar
kinda sounds like ur ecu is in limp mode check all ur grounds and wires. i had same prob and it was ecu in limp mode
Old Apr 3, 2011 | 01:11 PM
Crash83's Avatar
x2 on "check that the tps and the map sensor arent switch around"
Old Apr 3, 2011 | 01:29 PM
jaysalti's Avatar
I also had this issue. Had to trade out the ecu with a phearable p28 to fix the issue.
Old Apr 4, 2011 | 03:57 PM
kbear's Avatar
ic thanks for the info guys ill check the tps and the map sensor!
§95HATCH§
Apr 6, 2009 12:40 PM
ek9_Junkie
Mar 15, 2009 04:40 PM
5_Lug_B
Jul 17, 2007 04:32 PM
hybrid98
Aug 13, 2004 04:57 PM
lysergican
Jul 12, 2002 04:29 AM
