New distributor info for LS/B20 swap into '99 - '00 Civics
Old Apr 2, 2011 | 08:39 AM
94EG8's Avatar
Seagull Management
Default New distributor info for LS/B20 swap into '99 - '00 Civics
For those of you swapping a B18A/B18B/B20 into a '99 - '00 Civic (except HX/Si) you will most likely have run into an issue with distributor plugs not matching up, the '99 - '00 Civics (except HX/Si) use a small plug, Integras and '97 - '98 CR-Vs and all JDM CR-Vs use a large plug. This has meant cutting and splicing plugs or building a hybrid distributor. However, I just realized that '99 - '01 CR-Vs use a small plug distributor, these fit all B20s and B18A/B18B engines and make for a plug and play setup. Still no OEM option for those with B18C/B16 engines unfortunately.
Vamikeymike
Feb 12, 2013 06:19 PM
94EG8
May 4, 2011 03:30 PM
Lynx
Jul 21, 2009 05:53 PM
blue_delsol
Apr 6, 2004 01:13 AM
guyuenvy
May 7, 2002 02:47 PM
