Car stuttering
Old Apr 1, 2011 | 07:18 AM
Vince7AtVsG's Avatar
Default Car stuttering
Hi! I have an accord 6th 4 cyl and i'm having some stuttering problem when the car is running under low rpm but the idle is fine.
Old Apr 1, 2011 | 05:58 PM
phootbag's Avatar
Default Re: Car stuttering
A/T or M/T?
Could be a lean misfire caused by plugged EGR ports. Or, not.
Need more information about symptom. Throttle position, uphill/downill/flat, RPM range problem is noticed, hot/cold, turning/straight, heavy acceleration, light acceleration, cruising etc.
Need more information. Anything now would be a guess.
Old Apr 1, 2011 | 10:56 PM
The car is an M/T. It usually happened when the engine is cold under heavy acceleration in a uphill. Sometime when braking and the Rpm is below 2000, the same problem appears again. The spark plug cable has been changed.
J Corner
Dec 1, 2010 04:20 PM
J Corner
Nov 29, 2010 11:27 AM
clean3two3
Oct 24, 2007 02:19 PM
Kyles ej1
10
Jun 11, 2006 02:36 PM
WuRKD b16
Sep 24, 2003 11:44 AM
