Kirkey seat Brackets
Old Mar 31, 2011 | 09:38 PM
jamaljbenoit's Avatar
Default Kirkey seat Brackets
Can any of you guys using the kirkey seats give me some pointers on how you mounted your seats or fabbed your brackets. Pics would be wonderful. I have an EK chassis
Old Mar 31, 2011 | 09:40 PM
theidealone's Avatar
Default Re: Kirkey seat Brackets
All I did was use spacers and some steel strap. I put the strap from slider to slider, one in the front, one in the back. I used spacers because one of my sliders sits lower than the other (89 Civic), to keep it level across. Then bolted the seat to the strap. Its nice and square, sturdy, and simple. And adjustable.
Old Mar 31, 2011 | 10:31 PM
rudebwoy's Avatar
I use a seat bracket made for after market seats in civics weld another bar to the center to match size of the kirkey seat drill the holes in the seat and bolt down, then made another braket to mount the back rest to the roll cage. this is a fixed mounting and sits very low. I'm 6ft 1 in. tall.
Old Apr 1, 2011 | 07:16 AM
The Show Stopper's Avatar
we built braces & mounting tabs off the roll cage. we just bent tubing from the cage & looped it around (but you need to look closly to see it.
Old Apr 1, 2011 | 07:12 PM
boostontheD's Avatar
i got a bracket off ebay.
this is the outside of mine.
the inside
what the bracket looks like
now i also have the pro drag version. the bottom is not flat. i know a couple people that just ran metal across the bottom of the bracket to mount the economy drag style seat which has a flat bottom
91Ls_civic
Feb 6, 2012 07:22 PM
andysila
Jan 12, 2006 05:38 PM
Race Egr
Welding / Fabrication
11
May 21, 2005 07:32 PM
gsirnj
Mar 19, 2003 03:24 PM
misledyouth
11
Nov 24, 2002 04:56 PM
