99 integra ls vtec
Get guys,
I have a 99 integra with a ls vtec, I just put the motor together and came across a problem. It's a b18b1 with pr3 pistons and a b16 head port and polished with Gsr cams and a p73 type r manifold protection and polished matched to The head.
The car starts bogging with trying to step on the peddle, it sounds like its running on three cylinders, then it goes away if I mess with the peddle. And sometimes it doesn't bog when I floor it, it's like a guessing game with the peddle,
I was thinking maybe a bad tps or bad injector?
Any ideas would be greatly appreaciated
Oh yea I'm running a p72 and have two cell, code number 23 knock sensor, BC I don't have one plug on my ls block, and I also have code 41 which is o2 sensor BC I have no cat, u have a test pipe
Get a jumper harness and run a p28 so you can have the knock sensor disabled. I had the same problem on my ls-v. I was running a p72 also and had the knock sensor code. My car would bog out like he'll and felt like it was on 3 cylinders. Give it a try, trust me you will be satisfied
Yea that's what I'm trying to get a humerus and a chipped ecu to get rid of the knock sensor and the secondary o2 sensor, do u really thunk the bogging us occurring because of the ecu?
You also can try to use a ls ecu which would be p75. Run your car and it should be better since the ls ecus don't require a knock sensor and the only downside would be that you won't be popping vtec
4drteg54321
Jul 7, 2008 03:09 PM
type-t
Mar 26, 2005 01:11 PM
