F22B1 Rebuild
Hello HT im currently rebuilding my accords engine had a serious knocking noise so im pulling the motor. I already had plans on rebuilding so I bought oil and water pump, gasket set, o rings, bearings, pistons w rings timing belt and pulley. My question is there are two crankshaft kits at my local autoparts store which one has a 14mm and the other has 16mm. Does anyone have an idea which one i need both have the same specs both say my engine code f22b1 please i need this info asap its currently stopping me from completing my rebuild.
