transmission problem
Old Mar 31, 2011 | 03:08 PM
justin0498's Avatar
Icon2 transmission problem
ok so my question is... would it be better to rebuild my tranny or just go get a rebuilt one? i have a 1992 4door Accord with auto trans and i was driving today and it was fine then all of a sudden it jumped out of gear like it went into neutral and jumped back into gear did that for a while and now it doesnt pull very much taking off and wont change gears at all.....second question is would that just be the bands or could it be a sensor or what?.... and the reason i have an auto trans is cause the soon to be wife cant drive a manual and i dont have the patients to teach her
Old Mar 31, 2011 | 03:48 PM
phootbag's Avatar
Default Re: transmission problem
The auto trans in a Honda is a constant mesh configuration just like the manual. It uses clutch packs instead of synchronizers and shift sleeves. The clutch packs are controlled by a complex array of check valves, pressure/spring valves and a few electronic solenoids.
If you are lucky, you can replace a faulty shift solenoid pack. It is external and not that expensive. However, few are that lucky. Most likely you need to replace/rebuild the transmission as you suspect.
You may find a remanufactured transmission if you are lucky. You can try your luck with a junkyard trans ( don't buy one that doesn't have a warranty ) or you can have a shop or yourself rebuild the current trans.
Rebuilding isn't particularly difficult. It is a pain in the *** due to all the small parts. Plus, you don't know exactly what went wrong and what to look for when the trans is apart.
Old Apr 2, 2011 | 08:06 AM
justin0498's Avatar
thanks.... but yesterday it was shifting fine and now it wont shift at all again any reason why?
MeDuncan
Oct 24, 2014 05:04 PM
andyz
Dec 9, 2013 08:40 PM
LeegodaEG
May 6, 2013 10:28 AM
keanevann2005
Jan 4, 2012 08:57 PM
LSegHatchy
Sep 13, 2006 02:34 PM
