Black Smoke!
Old Mar 31, 2011 | 06:55 AM
K_Simm_94LX's Avatar
Default Black Smoke!
Ive got a 94 civic Ex with aftermarket straight pipes and everytime i get on it it spits some black, oil looking stuff out of the tailpipe along with black smoke. I know when a head gasket is blown it would be white smoke and there will be a milky, watery substance on the dip-stick, but there non of that. Does anybody know what it could be??
Old Mar 31, 2011 | 07:24 AM
wc4ohio's Avatar
Default Re: Black Smoke!
Your AFR is too rich... is your check engine light lit up?
Old Mar 31, 2011 | 07:29 AM
yeah it is, what do i need to do??
Old Mar 31, 2011 | 07:36 AM
wc4ohio's Avatar
Determine the CEL code... it's different for every engine, usually a shop manual will tell you how to check the code, or you can go to autozone and they will use their code scanner for free. It's probably your oxygen sensor, but it could be something more complex and more expensive. Go check the codes first.
Old Mar 31, 2011 | 07:39 AM
well when i start the car she wants to die out so i have to give it alil (neighbors arent to happy) to keep it goin. I know thats the Mass air flow censor but dk how to fix it. the only reason i bought this car was so i can take it to school with me in july.
Old Mar 31, 2011 | 07:46 AM
wc4ohio's Avatar
I could be wrong, but you probably have a MAP sensor instead of a MAF sensor. It's an easy fix... it should be bolted onto the throttle body.
Old Mar 31, 2011 | 08:30 AM
wc4ohio's Avatar
Hondas are easy to fix. Just be glad you don't have a Ford like me. Just changing the rear spark plugs on my Taurus is more difficult than anything I've done with a Honda.
Old Mar 31, 2011 | 08:45 AM
so what do i need to do to fix it?
Old Mar 31, 2011 | 08:47 AM
crazyazclown's Avatar
all race cars run alittle rich lol.
Old Mar 31, 2011 | 09:04 AM
well yeah, but the size of this puddle under tail pipes in crucial. its like my car is spittin a bottle of water on the ground when its jus sittin there hummin
Old Mar 31, 2011 | 10:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Pull the engine trouble code and post up what it is, then we can help you. You can find how to do that all over the internet. www.google.com
2000si2001lx
Dec 15, 2013 06:22 AM
FearTheH
20
May 13, 2009 03:46 PM
9hatch6
Apr 3, 2006 12:09 PM
hatch34
Feb 12, 2005 02:22 PM
mattharper
Dec 20, 2004 09:02 AM
