fluctuating idle after warm up?
Old Mar 31, 2011 | 01:48 AM
dc4teg95's Avatar
Default fluctuating idle after warm up?
So im having a idle issue that I can't seem to figure out. After my car warms up to op temp the idle starts to fluctuate between 1000 to 1500. If im idling long enough sometimes it it will eventually stop and return to 850 as normal. Happens every time I come to a stop. I have tried cleaning the iac and also replaced/cleaned the replacement. If I unplug it while its bouncing it idles perfect. I don't have any code. Could have been a bad replacement iac but idk as I don't have another to try. I don't have a fitv as my motor is obd2. Anybody have any ideas
Old Mar 31, 2011 | 04:40 AM
geetee74's Avatar
Default Re: fluctuating idle after warm up?
was the replacement iac new?
Old Mar 31, 2011 | 05:07 AM
dc4teg95's Avatar
No it was a used one I had laying around so im not ruling it out yet. Just need to find a known good one to swap it out
Old Mar 31, 2011 | 05:20 AM
geetee74's Avatar
im leaning towards the iac. get a new one and try that!!!
Old Apr 1, 2011 | 01:10 PM
dc4teg95's Avatar
Got another iac ima try. But before I changed it I figure I try cleaning the throttle body. Well it smoothed the idle issue out but it stayed at 1200 rpm. So I adjust the idle screw to drop the idle but once I got it going down it started to surge again.
Old Apr 1, 2011 | 01:13 PM
cetcivic's Avatar
no one wants to hear the truth
try bleeding the coolant system...may have air pockets
Old Apr 3, 2011 | 03:44 PM
dc4teg95's Avatar
Ok well found another iac I had that I forgot about and swapped it on everything so far is good. Idles smooth and right at bout 850-900. Only question though is I don't throw and cel but if I go to check the code it still shows code 14 which is the iac code. Do I just reset the ecu or does it mean the iac is still bad even though everything seems normal now?
Old Apr 4, 2011 | 06:41 AM
HondaJTM90's Avatar
I hav similar problem in a way, Iv owned lots of hondas my whole life and hav done minor things but I cant post on the site yet cause its my first day but i need to kno asap about som things.... I bought a 93EJ1 with a LSV and am running a p28 chipped, when i drive it it like laggs bad b4 vtec like 3400rpms then speeds up fine and when i hit vtec i can hear it pop but its not rly feeling strong and then the CEL comes on... wtf so i did the paperclip trick it does a quick flash then long long then short short so its code 22 but the quick flash when i turn the ign is that code 1?? so will a sohc vtec solenoid work and the lagg part rly makes me mad... i changed the oil, seafoamd it and cause somtimes it idles fluctuates i did throttle cleaner which helpd a little. But is it my clutch?? cause its missing the metal plate that goes out side the bell housing, i guss it keeps the clutch cooler or somthing but idk theres lots of snow up here so could the clutch be damaged from being wet?? or should i do a tranny fluid change to c if that helps?? im lost on things so i appreciate the help cause i cant post forums yet.......
dc4b20
22
Dec 3, 2012 09:54 PM
dirtyharryhatch
Dec 14, 2011 05:45 PM
averyvm
17
Jan 17, 2007 11:51 AM
PWRDbyHseries
Oct 18, 2006 05:44 PM
JSR
May 17, 2006 10:27 PM
