01 accord v6 vtec, code= every cl missfire
Its only noticable down low, but if u rev it up it goes away. I was told that there is no fuel filter in this car, the plugs look fine, the odds of it being a coil is slim because every cl has one and every cl is missfiring. It looks to have a new rotor on it........ any ideas? Thats the only code this car is throwing btw
sean
sean
phootbag i'll have to check that, guy above its coil over plug i dont have plug wires. Its only a missfire at 2000rpms and under
map read like 4.7ish volts. This car is a bitch to diagnos. I still dunno whats causing this. Maybe the plugs arent gapped properly
I doubt the MAP is 4.7 volts. At hot idle it should be around .88 volts. If it were 4.7 volts it probably wouldn't run at all.
If MAP is higher than .88, say around .95 or above 1.0 I would perform a valve adjustment.
You should bump after you check valve adjustment.
Tex Blackwell
Apr 13, 2005 04:03 PM
