gsr build clutch question
My build
11:5 to 1 Compression Je Pistions 81.5mm bore
Eagle rods
stock crank
blox type b cams, springs retainers tb.
Also will be spraying a 75 shot at the track
This car will be used as a daily driver/ tracked once a month
I was told an oem exedy clutch with a 7.5 lbs fidanaza flywheel will work. And I also have been told it will not work
Just looking for some input ..
Eagle rods
stock crank
it will work but will not last as long as normal. best bet is to go with a mild aftermarket like a street strip disc or a dual friction style. i have had the centerforce dual friction on the bottle b4 and worked well and was good price right now i have a act 4 puck sprung hub with a xtd street light 11 lbd flywheel in my gsr and it works great and engagement is not to harsh at all.. hope this was so,e help for you
jetspeedz
Sep 8, 2009 08:24 PM
