Free Injector Service Upgrade to H-T Members!
***FOR ALL HONDA-TECH USERS, SPECIAL FORUM UPGRADE TO OUR FORUM DYNAMIC SERVICE FOR THE PRICE OF OUR BASIC SERVICE, AND †FREE SHIPPING!!!!***
****Make sure you write at the top of the service form that you are a member of Honda-Tech!!!****
DeatschWerks Injector Services
Available on any gasoline fuel injector...OEM, Aftermarket, Sidefeed, and Topfeed.
We have taken what we have learned from building precision high flow injectors and applied these same principles to develop the ultimate injector cleaning and flow testing system. THREE levels of service are available to suit your needs, but each service receives the same quality and attention to detail that we put into our own highflow injectors. Also, all injector services are performed on the same precision calibrated equipment that we use on our own injectors...so you know the results you get are dead on.
Ordering
Ordering injector services through DeatschWerks is quick and easy. Simply choose the injector service you want (see descriptions below). Print out and complete the PDF order form available on our website: DeatschWerks Injector Service Order Form. Then, package your injectors with the order form and send it to the address at the bottom of the form. Be sure to package your injectors in plastic to ensure no residual fuel is leaked during shipping! Feel free to contact me if you have any questions or need help with which service to choose.
Basic Service - $19/Injector
Looking for better gas mileage, smoother operation, and crisper acceleration?
Installing used injectors and want to be sure they are clean and operating properly?
Then the Basic Service is for you!
PROCESS BENEFIT
Forum Special Dynamic Service - $19/Injector and †FREE SHIPPING back to you!
The BEST deal in town!
PROCESS BENEFIT
Dynamic Service - $29/Injector
Having an engine problem and suspect the fuel injectors?
Tuning your car for more boost and want to yield the higher and safer whp?
Then the Dynamic Service is for you!
PROCESS BENEFIT
Dynamic PLUS Service - $39/Injector
Are you the picky type who demands only the best for their car?
Are you a tuning your car for maximum power and efficiency?
Then the Dynamic PLUS Service is for you!
PROCESS BENEFIT
† International shipping will be reduced by the cost of domestic shipping ($13 USD), please contact me for International shipping rates.
Ordering
PROCESS BENEFIT
- 3-step Ultrasonic Cleaning
- Optimum Atomization and Flow
- Replace O-rings, Filters, and Seals
- Ensure Leak Free Operation
- Check Coil
- Discover Coil Problems
- Leak Test @ 100psi
- Find Leaks at Pintle
- RPM Ramp Test - Exclusive DeatschWerks test!
- Pulse-Width Ramp Test - Exclusive DeatschWerks test!
- Spray Pattern Analysis
- Verify Proper Atomization
- Static Flow Test
- Check Balance of Flow Rates
- ID Etching, links each injector to results on report
- Lubricate and Bag, preserves optimum working condition
- System Calculations, min/max/avg flow and system balance
- Basic Report (1 page)
PROCESS BENEFIT
- everything in the Basic Service plus ...
- everything in the Dynamic Service minus the pre-test!
PROCESS BENEFIT
- Flow-Rate Pretest, for before and after comparison
- Dynamic Flow Testing, simulates real driving conditions
- Fuel Pressure Calculations, valuable tool for FMU/AFPR users
- Performance Calculations, defines limits of fuel system
- Dynamic Report (2 page)
PROCESS BENEFIT
- everything in the Basic AND Dynamic Service plus ...
- Customer Defined Testing Parameters, you can choose testing pressure, duty cycles, rpms, etc. to build a complete custom test
- Advanced Coil Testing, loaded/unloaded and at various operating temps
- True Balancing and Blue Printing, bring atomization and flow to within 3%
- Lag Measurement, valuable tuning tool (upon request)
- 10-point Dynamic Test, maps injectors through all duty cycles
- Linearity Testing, graphs injector flow during entre range of duty cycles
- Dynamic PLUS Report (3 pages)
Had quite a few of you guys take advantage. Thanks!
Let us know if you need your injectors clean and/or flowed. We will also flow test fuel pumps and give you a detailed flow report.
This will be an ongoing offer for H-T members! The season is coming to a close and winter project time is a great opportunity to take advantage of getting clean injectors.
Fuel Injector Clinic
Sep 29, 2014 06:14 AM
Performance
Apr 24, 2013 08:01 AM
