Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cat-less test pipe - 02 CEL
Old Mar 29, 2011 | 07:39 AM
j.bro's Avatar
Default Cat-less test pipe - 02 CEL
I'm thinking of grabbing one of those cat-less test pipes for an easy exhaust mod.
Will this cause a CEL for the 02 sensor. These test pipes do come with o2 sensor bungs.... anyone have one of these or know FOR SURE if this would be the case.
thanks,
J.B
Old Mar 29, 2011 | 09:47 AM
01_civic's Avatar
Default Re: Cat-less test pipe - 02 CEL
just do the o2 sensor mod and you won't throw a code. You'll still fail emissions test if your'e in cali but just put your stock cat back on when you do smog. Where u located?
Old Mar 29, 2011 | 11:27 AM
toyomatt84's Avatar
Sanji
thanks,
J.B
If you're looking for a raspier exhaust without any performance gain, then you can run a test pipe with either spark plug defoulers spacing the secondary oxygen sensor or an oxygen sensor simulator. But, as already stated, you will not pass emissions in any state that requires a sniffer.
Old Mar 29, 2011 | 11:55 AM
j.bro's Avatar
I am in Canada, the land of automotive lawlessness...
more information on the spark plug defouler method and how it works?
Old Mar 29, 2011 | 12:07 PM
toyomatt84's Avatar
Sanji
Here's a simple Google search: http://www.google.com/search?q=spark...uler+o2+sensor
Basically, you stack two defoulers and run the Oxygen Sensor. It spaces the sensor out from the exhaust flow, to prevent the sensor from receiving the full-stream of exhaust flow.
But, as I stated earlier, you're not going to gain any performance from this. You'll only see a change in exhaust/engine noise.
Old Mar 29, 2011 | 02:35 PM
j.bro's Avatar
Hmmm seems pretty legit.
Anyone have experience actually running this stacked defouler set up with no cat?
Old Mar 31, 2011 | 11:36 AM
da1lydr1ver's Avatar
i had the 2 stacked defouler thing when i was running a race header that eliminated the cat on my '02 civic. i threw a CEL, but others seem to have some luck with it.
mxracer420
Mar 25, 2010 04:33 PM
mistawho
Dec 20, 2005 09:01 AM
SubTitle
10
Oct 18, 2005 09:33 PM
Chris_Bye
May 1, 2005 07:56 AM
amrintegra
Nov 5, 2001 07:21 AM
