b16 missing and wont idle sometimes help?
Old Mar 29, 2011 | 07:05 AM
92d15b7's Avatar
Icon2 b16 missing and wont idle sometimes help?
ive got a 91 ef swapped with a b16a and gsr tranny swapped into it. Im trying to figure out why it seems like its missing when i take off sometimes, sometimes it doesnt then it does it when im on the throttle at high rpms occasionally. Ive also had a few istances where it will be running fine then it wont hold idle and shut off ill try crankin it over and all it does is turn over and try to start but then if i let it sit for a few mins itll start up but when i go to take off itll just start jumpin and wont move and has no throttle response just makes a noise did it a few times this morning then i started it up and took off and it ran fine? any help?
Old Mar 29, 2011 | 07:48 AM
tonythetuner®'s Avatar
Default Re: b16 missing and wont idle sometimes help?
Do you have a check engine light? Is so wat are the codes? kinda seems like your running no o2 sensor. But that will not cause it to not start..
Old Mar 29, 2011 | 10:49 AM
92d15b7's Avatar
yeah check engine light is on havnt checked it.. and yeah iw as thinkin maybe the o2 sensor was bad to
Old Mar 29, 2011 | 10:54 AM
Funtington777's Avatar
what the **** are you on here for then? Go check your engine code and fix the problem.
Old Mar 29, 2011 | 11:15 AM
Check and post your codes we can help more after that.. till then its just guessing in the dark
Old Mar 29, 2011 | 07:06 PM
92d15b7's Avatar
Icon2 Re: b16 missing and wont idle sometimes help?
cel gave me16 and 3 or something like that but i looked it up and it said injectors was one and cooling temp gauge or something was the other now my car wont even start at all just turns over and is getting spark would the injectors be enough to keep it from running?
Old Mar 30, 2011 | 06:01 AM
Yes the injectors will stop the car from starting. Also the code 3 is easy to fix the coolent temp sensor its on the side of the head its a 2 wire plug make sure its plugged in and the wires are not pinched or broke if it all looks good the sensor its self is probly bad. Now back to the injectors there probly wired rong or your using a resistor box and shouldn't be wat obd are you running and wat injectors are you running??
77highboy
Jun 21, 2013 04:16 PM
Poroshok
Feb 1, 2010 05:12 AM
Civic_07
Jun 10, 2008 04:49 PM
'01silveri'sh'
Feb 22, 2006 08:50 PM
drunk
Dec 29, 2002 11:43 PM
