A little help?
Old Mar 29, 2011 | 07:03 AM
akkord94's Avatar
Icon2 A little help?
I was wondering if you guys think this is a good deal. I looking to start a motor project in a 97 coupe and I found a CRV (b20z) motor with 105K miles on it for $500. Problem is it will need the following to get it running. Motor Mounts, SI bracket for Mounts, ac conversion bracket, power steering bracket, (JDM) jumper harness for ECU, axles, Phearable ECU, tranny, clutch, front and rear main seals, oil pan gasket, valve cover gasket, dist. O-Ring, exhaust cam seal, head gasket, & APR studs and bolts. Good things are that it just had the timing belt replaced and I have seen the motor run, but I think the guy may be asking a little too much. This is my first encounter with this motor so I thought I would ask the pros.
Old Mar 29, 2011 | 07:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: A little help?
You should make your thread title a little bit more descriptive before it gets locked. Did you check the FAQs?
Old Mar 29, 2011 | 07:30 AM
foo fighters's Avatar
I second that. I researched my D15B swap for like a whole month(not on H-T) before i settled on it. To buy a swapped car is a gamble if you don't know ALL you can first. I.E. my bro bought an h22a swapped accord for $750 and it had wiring issues out the a$$,and a bolt where the V-TEC oil plug goes??wtf?
Old Mar 29, 2011 | 07:32 AM
Former User's Avatar
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
nano1589
Aug 5, 2010 05:29 PM
cookiemonsta08
Mar 13, 2010 09:46 PM
RVARGAS64
Mar 5, 2008 04:20 PM
tolowhb
Mar 11, 2003 06:38 PM
tolowhb
Mar 11, 2003 06:37 PM
