finishing a paint job
Old Mar 28, 2011 | 07:30 PM
ryanangelo212's Avatar
Default finishing a paint job
well, i finally got around to getting to old da painted. did the body work myself then had a friend who works at a shop primer it and spray it white. it was a 1 stage white. anyway, after it dried i had to get it outta there, so i have it in my garage now. my question is, after painting, what do you need to do to finish the job properly? (ie wetsand, if so what grit, or buff)
Old Apr 3, 2011 | 10:08 AM
CT-Matt's Avatar
Default Re: finishing a paint job
Here's a good read that should be able to clear up your questions.
https://honda-tech.com/forums/paint-body-84/everything-you-need-know-about-autobody-repair-1962364/
Old Apr 4, 2011 | 03:49 PM
Fibercation's Avatar
thats the problem with single stage....you can't do anything with it....its a crap paintjob. use base and clear next time so u can sand out imperfections and orange peel.
Old Apr 4, 2011 | 06:43 PM
Hawkze_2.3's Avatar
Why would you not be able to cut and buff single stage?
Old Apr 8, 2011 | 05:02 AM
Thrillmess's Avatar
I finally found time for getting to elderly painted. did the body work myself then had a mate who works at a shop primer it and spray it white. it was a one stage white. anyway, after it dried i had to get it out a there, so i have it in my garage now. my query is, after painting, what do you require to do to finish the job properly.
Old Apr 8, 2011 | 07:48 AM
Hawkze_2.3's Avatar
Depends on how it looks...if his paint job came out perfectly smooth (and you're happy with) then just leave it how it is and try to let it cure for a few days. If it has has trash in it or orange peel, then you can sand it smooth and buff after it cures.
Tom B.
Paint and Body
Aug 8, 2015 11:14 AM
pprowler6
Paint and Body
29
Aug 18, 2010 09:37 PM
alltech_hybrid
Paint and Body
Oct 11, 2007 04:04 PM
