swapped cluster and now have problems
Old Mar 28, 2011 | 03:03 PM
barcode31's Avatar
Default swapped cluster and now have problems
i got a 95 dx hatch and today i swapped in a new gauge cluster and now i got no turn signals and it wont go into gear (its a auto). checked all relays and changed turn signal salk and still nothing. i disconnected the battery to try to clear whatever the prob was with it not shifting out of park. on the indicator on the cluster it doesnt light up what position the tranny is in. any help would be great
Old Mar 28, 2011 | 03:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: swapped cluster and now have problems
How does a cluster stop you from shifting into gear?
Did you try the old cluster to see if the problem remains?
Old Mar 28, 2011 | 03:48 PM
barcode31's Avatar
i found in haynes repair manuel that if the cluster has probs itll lock the shifter. somewhere i got a relay out i think. the old cluster got knocked off the roof of the car while the new one was going in. i have been swappin parts around in the two clusters to try to get something going but i have had no luck. the turn signals really baffel me
Old Mar 28, 2011 | 03:50 PM
The Grumpiest
Okay. Not familiar with automatics at all so that had me puzzled.
Old Mar 28, 2011 | 05:17 PM
Former User's Avatar
Not sure what you read in the Haynes manual because a bad cluster would NOT affect the interlock system. My guess is that 10A dash fuse 15 is blown.
Old Mar 29, 2011 | 08:43 AM
barcode31's Avatar
i changed the fuse again and it worked. the fuse diagram on here was a big help aslo. thanks for the help
Old Mar 29, 2011 | 09:02 AM
Crashtestdummy's Avatar
Thats why i hate automatics, one little things goes wrong and your car has pms all of a sudden
Old Mar 29, 2011 | 10:45 AM
jraggett's Avatar
lolololol @ pms
DeLSoLRo
15
Aug 4, 2012 09:02 PM
kcrxxx
Jul 27, 2007 01:42 PM
ronintegra
Jan 3, 2006 12:10 PM
