97 del sol rear bumper removal
Old Mar 28, 2011 | 10:36 AM
hawaiiboi's Avatar
Default 97 del sol rear bumper removal
how do you remove the rear bumper on a 97 del sol?
Old Mar 28, 2011 | 11:28 AM
Mattdg67's Avatar
Default Re: 97 del sol rear bumper removal
Just took mine off the other day, it has 2 clips on the underside (near towhook), 2 screws (one in each wheel-well), the 4 screws on each mudflap, and three nuts on the inside of the trunk.
Old Mar 28, 2011 | 12:41 PM
thbx59's Avatar
When I did mine I found that patience, lots of lighting and a bit of cursing helped. Plus I have a trailer hitch for some reason (previous owner) which was kind of in the way.
Old Mar 28, 2011 | 04:04 PM
SoFlaNut's Avatar
What trailer hitch do you have, is it tucked under? Been thinking about putting one on mine for a bike rack.
This will also help me since I have to replace my rear bumper also. Thanks
Old Mar 29, 2011 | 07:21 AM
hawaiiboi's Avatar
do you need to remove the tail lights as well?
Old Mar 29, 2011 | 08:43 AM
Markley02's Avatar
It is 5 nuts, not 3 in the trunk. Otherwise, really good info. The ones inside the trunk are 10mm and I think the ones on the underside are 12mm.
Nope.
Check out this link. (not my page BTW)
http://www.knology.net/~jediklc/rearbumper.htm
Old Mar 29, 2011 | 08:58 AM
Mattdg67's Avatar
Thanks for the correction. Mine had 3 because of the bracket was broken, ordered a new one though.
eksleeper97
Mar 25, 2010 07:52 AM
vietshinobi
May 2, 2006 09:35 PM
gSx.
Dec 19, 2003 02:04 PM
FoRmerLyMentAL
Mar 10, 2003 05:49 PM
turbomonkeyexpress
Mar 2, 2003 05:47 AM
