F22B2 Mystery Knock?
Old Mar 27, 2011 | 08:20 PM
SHORob's Avatar
Default F22B2 Mystery Knock?
Hey Guys, I've been a long time reader but never had the chance to post.
I've got a 95 Accord (F22B2) 5-Speed.
It's developed a noise that sounds EXACTLY like worn rod bearings (only noticeable when warm and between 2000-3500 rpms).
I checked oil pressure both hot and cold, and both are within spec..
So, I figured it had worn rod bearings, or something of the nature. I dropped the pan, and plastigauged everything, and all was within spec. The rod bearings had hardly any wear, and everything was tight (Bearings, no play in rods).
I changed the rod bearings anyway, and the noise still persists. It's coming from the rear of the block , hard to discern exactly where (stethescope doesn't help, but it's NOT coming from the oil pan from what I can tell.) Noise does NOT change when spark plug wires are removed one by one.
Since I'm 99 percent sure it's not crank/rod/wristpin related, the only thing I can can think of at this point is something balance shaft related. Am I barking up the wrong tree? Any suggestions?
EFz6er
Jan 28, 2013 05:20 AM
bseries_ben
Feb 13, 2007 04:53 AM
espanol
Apr 20, 2003 10:04 AM
B20zvtecek
Oct 28, 2002 07:11 AM
B20zvtecek
Oct 28, 2002 01:35 AM
