bent rod??
Old Apr 19, 2003 | 12:05 PM
espanol's Avatar
Default bent rod??
What does a bent rod sound like?? Does it increase in sound as you rev up the motor?
Old Apr 19, 2003 | 12:09 PM
DIRep972's Avatar
Smarter than you
Default Re: bent rod?? (espanol)
not ur car is it?
Old Apr 19, 2003 | 12:23 PM
CRVRX's Avatar
Default Re: bent rod?? (DIRep)
That sounds like a rod bearing if it gets loader with revs. Depending how bad the rod is bent it might not make a noise.
Check your oil pressure too.
Old Apr 19, 2003 | 02:22 PM
espanol's Avatar
Default Re: bent rod?? (CRVRX)
Well, the noise doesn't get louder with increasing the revs. Oil pressure is good, and the car still makes great power...hmmm..
Old Apr 19, 2003 | 02:29 PM
RedHB's Avatar
I think you might have spun a rod bearing. Just to be on the safe side, I'd suggest you drop the oil pan and check the rod bearings. It'll only cost you five quarts of oil and about 2hours out of your time.
Old Apr 19, 2003 | 03:08 PM
espanol's Avatar
Default Re: bent rod?? (RedHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHB &raquo;</TD></TR><TR><TD CLASS="quote">I think you might have spun a rod bearing. Just to be on the safe side, I'd suggest you drop the oil pan and check the rod bearings. It'll only cost you five quarts of oil and about 2hours out of your time.</TD></TR></TABLE>
i already did that..I thought a bearing made a kind of rattle in a can sound..I 've heard spun bearings before and this doesn't sound like that..
Old Apr 19, 2003 | 04:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
It does sound like you spun a rod bearing.
art
Old Apr 19, 2003 | 09:38 PM
earl's Avatar
Default Re: bent rod?? (Arturbo)
If you bend a rod, the motor will probably not turn over and it sure won't make power. A spun bearing will sound like a hammer hitting inside and you will lose lots of oil pressure.
Old Apr 20, 2003 | 07:21 AM
espanol's Avatar
Default Re: bent rod?? (earl)
Thanks for all the good feedback...
Old Apr 20, 2003 | 10:04 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">If you bend a rod, the motor will probably not turn over and it sure won't make power. A spun bearing will sound like a hammer hitting inside and you will lose lots of oil pressure.</TD></TR></TABLE>
If the motor was loosing oil pressure then it still wouldn't be making good power.??
EFz6er
Jan 28, 2013 05:20 AM
D16Y8-JDMYO
Oct 22, 2006 04:02 PM
boostedeghatch
15
Mar 2, 2005 12:55 PM
Unsivil_audio
Jan 19, 2005 11:23 AM
whagkangmakulet
Feb 23, 2002 10:15 AM
