need help picking a amp for my JL audio 10w1v2.4 sub
Old Mar 27, 2011 | 05:56 PM
dcsports's Avatar
Default need help picking a amp for my JL audio 10w1v2.4 sub
well i guys i know close to nothing about audio not well i need help picking a amp for my JL audio sub which is the 10w1v2.4 sub here are the specs for my speaker http://mobile.jlaudio.com/products_s...p?series_id=15 i am looking for a more clean sound not to huge on bass just want a clean bass clean sound nothing that will make my car rattle i am also looking to get maybe polk audio front and rear speakers this will be for a 1997 civic please help also have monster cables for this
Old Mar 27, 2011 | 05:57 PM
dcsports's Avatar
Default Re: need help picking a amp for my JL audio 10w1v2.4 sub
10" Single 4 Ohm W1v2 Series Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
Recommended Power Range: 50-300 watts
Injection-molded, metallic-finish polypropylene cone woofer
Rubber surround with stress-relief
Customizable trim ring
Vented reinforcement collar
Elevated frame cooling technology enhances power handling and sound quality
DMA-Optimized motor system improves dynamic motor behavior
Insert molded suspension/coil/terminal sub-assembly
Floating cone attach method
Interlocking cone and dust cap enhances mechanical integrity and cone rigidity
1-year SonicElectronix.com warranty
Old Mar 27, 2011 | 08:30 PM
94_DC4's Avatar
How much are you looking to spend for the amp?
Old Mar 28, 2011 | 08:10 PM
fcm's Avatar
fcm
Old Fart
Find a mono block, [1ch] amp. with at least 150-200 watts RMS into 4 ohms.
The JL Audio JX500 is a little over-powered but it would work very well, just watch the input gain setting on amp. 94
Old Mar 29, 2011 | 08:16 AM
mhart's Avatar
http://mobile.jlaudio.com/products_amps.php?amp_id=608 with a 10" sub and only 150-250 watts it's not going to be loud enough to rattle stuff, it should just sound good.
Old Mar 29, 2011 | 11:11 AM
fcm's Avatar
fcm
Old Fart
Recommended optimum RMS wattage for that sub is about 150W-175W RMS... http://mobile.jlaudio.com/products_s...p?series_id=15
The JX250/1 is only 175W RMS into 4 ohms, [that's at 14.4V just barely enough wattage], although the JX500/1 is overpowered for the sub, [340W RMS into 4 ohms] it's far better to be overpowered then under-powered, the amps gain control can be used to control the output of the amp. 94
Old Mar 29, 2011 | 01:35 PM
edzy's Avatar
That has more to do with the enclosure itself rather than the sub.
Any amp that'll give you 300-500@ 4 ohms would work well.
If you don't have your front stage amped, get a 4 channel and use it power everything
Old Mar 29, 2011 | 05:28 PM
rjr162's Avatar
The JX line is a class A/B, so basically it's a bridged 2-channel. No big deal, but you could roll with a Memphis 16-PR2x100 and hit 300x1@4Ohms RMS for around $210.
Old May 3, 2022 | 08:32 AM
zholeman's Avatar
I have a JL A2150 amp hooked to this same sub and it sounds perfect!
rutherfordhigh
Audio / Security / Video
Nov 22, 2008 03:38 PM
deeweezy
May 19, 2004 04:23 PM
mrm1682
12
Mar 26, 2004 10:56 PM
b18tdelsol
Jan 7, 2003 08:25 PM
xJ.SLOTHx
Feb 14, 2002 11:12 PM
