Honda CR-V & Element 2WD & 4WD Element & CR-V
Engine mounts
Old Mar 27, 2011 | 01:46 PM
decode33's Avatar
Default Engine mounts
My 98crv car vibrates. The mount between the engine and firewall was broken, my mechanic changed it. Now the vibration is less but still exist. I tried to search for the other mounts under the hood but could not locate any. I can just see the mount near the firewall which I replaced. I believe there are 5 mounts. Where are they hidden.
Old Mar 27, 2011 | 03:31 PM
Hawkze_2.3's Avatar
Default Re: Engine mounts
There's 1 at each lower front corner of the engine bay, and those are usually torn. Their bolts can be accessed from the wheel wells.
Old May 30, 2011 | 06:56 AM
market525's Avatar
Bringing this topic back to the top .... Working on my 2000 CRV, and I see the LH (driver's side) front lower insulator is in rough shape. Those familiar know that this mount is held in with 2 bolts. Oddly, 1 bolt is missing.
When I put the proper size bolt in the hole (10X30 bolt) there seem to be nothing for it to thread into. From what I can see, you cannot access the top portion of where this bolts into.
Just seemed like an odd situation to me. Anybody have any experience with this type of problem?
Thanks, Steve
Old Jun 1, 2011 | 03:15 AM
rockwell's Avatar
thats an nice stuff it would help me a lot thank you....
Old Jun 1, 2011 | 06:51 AM
fast2camciv's Avatar
Thanks, Steve
i know exactly what you are talking about....but if you look, that hole your threading into, isnt the right hole. there are actually 3 holes in the mount. (2 on one side, 1 on the other) not sure what that blank hole is for, but there should be another hole on that side that WILL thread into the body. hard to explain but i hope that helps.
see how there is 2 holes on that one side? the bigger hole is the one your talking about...the smaller hole closer to the inside of the mount is the correct mounting hole.
meandino
Honda Civic (2001 - 2005)
Jun 17, 2009 11:20 AM
Christopherian1982
Feb 1, 2009 09:22 PM
