Oil feed fittings; Where to buy????
Old Sep 27, 2002 | 10:13 AM
justinCO's Avatar
Default Oil feed fittings; Where to buy????
I am setting up my oil feed line to go to a NPT T on the firewall before going to the turbo. I was following the image found in this thread:
https://honda-tech.com/zerothread?id=119681
But I cannot find the BSPT fittings anywhere. I have checked anplumbing, amstreetrod, summit, majesticturbo, inlinepro, and called a few local diesel turbo places, no luck anywhere.
Now some people have said that a 1/8 NPT fitting will thread into the block (b18c1 in my case). Is this really true? I do not want to mess up the threads obviously. But, if an 1/8 NPT will go into the oil port on the block ok then I can just get a 1/8 to -4 union and then use -4 straight swivel seals to run the hose to the T. I have searched every single thread on this and haven't been able to conclude on what to do. Thanks for any help.
Justin
Old Sep 27, 2002 | 02:27 PM
justinCO's Avatar
Default Re: Oil feed fittings; Where to buy???? (justinCO)
Well, if anyone cares, I was able to get everything squared away with some great help from Speed Freak. I ordered the bspt/npt fittings from http://www.pegasusautoracing.com. Here are the parts I used with the part # first:
1073 : Kit that contains 1/8bspt Male to 1/8npt Female fitting and 1/8npt Male to 1/8bspt Female fitting.
3250-02-04A : 1/8npt to -4an union fitting
4-21-S-S : -4an SS line with female -4an fittings already on it
You can refer to Speed Freak's graphic in this thread to get an idea of how the fittings go:
https://honda-tech.com/zerothread?id=275180
My setup is a little different than that graphic though. All mine will be is the -4 SS line from the block to a npt T on the firewall. The one line goes to the turbo oil feed and the other port on teh T goes to the stock oil sensor. There is lots of threads in teh archive on this topic, but none include the webpage and part numbers for the bspt fittings. 93LScivic has a thread with parts number but he used exclusively npt fittings in his setup, which would work fine too I think. Hope this helps...
Justin
ÁrniMkv
Feb 10, 2012 07:02 AM
DIYMIKE
Jan 24, 2006 05:14 PM
beemaz
Mar 8, 2004 06:24 PM
dohcvtec717
Apr 1, 2002 06:58 PM
Ri5e
Feb 17, 2002 02:20 PM
