H22a project: EF sedan
Old Mar 26, 2011 | 11:57 AM
On1Bruh's Avatar
Default H22a project: EF sedan
heyy! whats going on guys? i was just wondering if the h22 would be able to fit without having to fabricate? and if so what kind of motor mounts would i have to get, Also if i would be needing to get a custom wire harness? Thank you! I appreciate it! I'm going to need all the help i can get.
Old Mar 26, 2011 | 12:07 PM
john89crxsi's Avatar
Default Re: H22a project: EF sedan
http://www.explicitspeedperformance.net/ESPEFHF.html
they make the kit i am ordering for my swap.
Old Mar 26, 2011 | 12:26 PM
On1Bruh's Avatar
so no fabrication needed?
Old Mar 26, 2011 | 07:35 PM
They have a list of all the necessary parts, and odds and ends you'll need. I believe you have to have the passenger mount welded in.
Old Mar 26, 2011 | 07:42 PM
KINGVEM^^ED6's Avatar
its alotta work gl mine as well go k power
Old Mar 27, 2011 | 08:00 AM
KLeSe's Avatar
Its a common swap that is easier n cheaper than K swap with proven results. Do some research before geitting into it, it will save u a lot of time and money
Old Mar 27, 2011 | 09:59 AM
PeterVSays's Avatar
Old Mar 27, 2011 | 10:13 AM
On1Bruh's Avatar
as long as the web site http://www.explicitspeedperformance.net/ESPEFHF.html has all the detail for the swap, hoping that everybody and anybody will be able to help me through the process. thank you! but I'm still going to be asking all of question thought.
Old Mar 27, 2011 | 10:20 AM
if you are gonna do it make a extensive parts list and make sure you have everything needed before you start anything gl op keep us updated
Old Mar 27, 2011 | 10:21 AM
On1Bruh's Avatar
can this also go for the ee civic wagon as well? there kind of in the ef family?
Old Mar 27, 2011 | 06:35 PM
Ill be doing a build thread almost got all my parts together.
Old Mar 30, 2011 | 11:49 PM
On1Bruh's Avatar
aye man? does the web site also tell you on what kind of axles to use?
jayel79
Feb 1, 2009 11:09 PM
akouznet
Nov 12, 2008 10:57 PM
m00sie
Nov 22, 2007 09:24 AM
Corporation
Aug 21, 2004 11:05 AM
StorminMatt
Oct 7, 2003 05:33 AM
